I'm about settled down on dimensions again (
This will have a frontal area of 53 sq. ft., and will follow the aft template faithfully till about the first 22 degree point. The sides will taper in a couple of small angle changes.
The rocker angle aft of the wheels needs to be a little steeper than ideal at 4.6 degrees.
The area at the back will be ~17 sq. ft.
What kind of Cd should I expect out of that, considering it will be faired smooth and tight to the tow rig and have above average fairness in general?
2003 TDI Beetle
2002 TDI Beetle
Custom cab, auto, 3.55 gears
