Sorry, I wasn't clear as to what info I can't seem to get much info on (probably my search terms). The warm air intake I came across no problem, but having the intake located in an area that is of higher air pressure, similar to a ram air hood, but thinking more of the high pressure areas either low and in front of the front tires sucking air in from the fender well (cleanest I think?), or the upper area behind the front tires. Another option would just have a small scoop at the front of the car after areo-modding it.
I'll keep searching around too.
