2 Car H7 6W SMD LED Bright White Head Light Bulbs Lamp | eBay
good, efficient, and cheap headlight bulb replacement?
I welcome all feedback. if anyone has tried these already, please let me know.
( someone has raised the issue of these possibly having an incorrect beam pattern which might blind other drivers. I don't see why this should be the case, they look like nice headlamp bulbs.
however since I havent tried them yet I can't say ,but if it turned out to be the case I have a solution:
It wont be a plug-in-swap as it will require some modding the rear of the reflector plate.
I'd have a piece of 3" diameter PVC plumbing pipe, and I'd cut a piece around 2-3 inches long and mount the led so it shines through the pipe. I now have a narrower then usual light beam,and I can control the width of the beam by shortening or lengthening the pipe.
now all we need is to have them pointing correctly downwards and no oncoming motorists will have a problem. -again, I welcome all feedback)
