Old 01-15-2012, 04:16 PM   #4 (permalink)
Josh8loop
Definately a Modder!
These will most likely put out the equivalent light that a 20-25 watt light bulb would put out. Stock headlights on a car are around 55 watts. They might be ok for accent lights or backup lights etc, but not suitable for headlights. Don't let that stop you-they are really cheap and you can experiment.
2002 VW Jetta TDI 5-speed(completed 01M-5-speed swap at 155K miles) 45 MPG City with the 01M, 5-speed 60+ MPG City. Nokian Entyre Low RR Tires. Experimenting with the "Hybrid" 205 Deg F T-stat:
http://forums.tdiclub.com/showthread...=306799&page=4
The Following User Says Thank You to Josh8loop For This Useful Post:
Ryland (01-15-2012)
