Old 01-15-2012, 06:03 PM   #5 (permalink)
mans
Originally Posted by Josh8loop View Post
These will most likely put out the equivalent light that a 20-25 watt light bulb would put out. Stock headlights on a car are around 55 watts. They might be ok for accent lights or backup lights etc, but not suitable for headlights.
why is that?
doesn't 6w LED equal around 50w-60w incandescent?
I understood fluorescent was about 1/4 the wattage of the incandescent bulb, with led's using only 1/2 (or even less then 1/2) of the florescent. that would be about 1:9 or 1:10 so 6w led should give like 50w-60w equivalent.
am I making a mistake somewhere?
