Lean Burn is when the engine leans out the fuel to air ratio, Honda does this when the engine is under a light load, like while cruising down the highway, going from a standard 14.7:1 ratio to a ~20:1 ratio, allowing the engine to burn a lot less fuel after you get up to speed but to do this you need an ECU that allows this and you need a wide band o2 sensor, this is the 5 wire o2 sensor as it has a heater and more or less two different o2 sensors in one package.
A few people have swapped wiring harness so they can use the Civic VX ECU, and it seems like I saw a few of those on Ebay the other day, you would still need a button for that 3rd stage V-tec.
Getting the engine to fit in the car seems like more of an issue, but that is up to you and your skill set.
