Originally Posted by redpoint5
You are better off running HID lamps. You can get em for about the cost of the 4 bulbs on Ebay, and they draw 70w total. Most importantly, they give off more light which should make for a safer trip as long as they are adjusted to not blind oncoming drivers.
I agree, HIDs are amazing as far as light output vs electrical input. They are among the most lumens per watt out there. This is also why most warehouses and large areas use a similar technology like mercury vapor etc. Startup current on the HID's will be around 10 amps for a brief second until they normalize around 3-4 amps. By the way, quality in HID matters. Yes there are kits for $40-$70, but often the ballasts or bulbs go out prematurely. High quality ballasts and bulbs are a good idea.
