Old 01-16-2012, 07:20 PM   #37 (permalink)
aerohead
Cd?
Originally Posted by skyking View Post
I'm about settled down on dimensions again ( ).
This will have a frontal area of 53 sq. ft., and will follow the aft template faithfully till about the first 22 degree point. The sides will taper in a couple of small angle changes.
The rocker angle aft of the wheels needs to be a little steeper than ideal at 4.6 degrees.
The area at the back will be ~17 sq. ft.
What kind of Cd should I expect out of that, considering it will be faired smooth and tight to the tow rig and have above average fairness in general?
I've been studying trailers and commercial vehicles since early October and don't yet have any confidence in predicting Cds.
From what I've looked at so far,the theme is:
* match the tug height and width to trailer as close as possible
*do a full 'oval' nose on tug (elevation and plan)
*kill the gap in between
*turn the 'van' back into a 'fast back'(elevation and plan)
------------------------------------------------------------------------ So you're definitely sniffing at the right tree!
In SAE Paper # 860093,by Carr and Stapleford,Fig.8,something interesting showed up.
They took the same vehicle model and tested with three different backs.
*Van back had highest drag.Cd 0.327
* Notch back had next highest.Cd0.285
*Fast back had lowest,Cd 0.237 (just as Hucho promotes).
In a crosswind:
*Notch back sees up to a 33% drag increase @ yaw = 18-degrees
*Van sees up to a 12% drag increase @ yaw = 18-degrees
*Fast back sees up to a 14% drag increase @ yaw = 20 degrees
So the 'fast back' 5th-wheel might see a little higher drag increase than the van back in a crosswind,but in light or no wind she should return the best mpg.
If we could have a guestimate of the all-up weight for the rig,that would give us something to chew on.
Your mpg is going to track your Cd just like a car.At 55 mph,any 10% drag reduction is going to mean a 5% improvement in economy.
If your flow is 'clean' down to that 17-sq-ft exit area,compared with a 53-sq-ft frontal area,that suggests some tasty numbers!
If you were working it in the opposite direction,from 17,to 53,all else being equal,that would be a 3.11X increase in drag,and should mean a 1.55X mpg penalty.
If the composite Cd is lower (as it should),then the figures are even more liberal.
slowmover (01-18-2012)
