Thanks Phil, I was just looking at the template again when you posted. The back of trailer and is about 63% or so. Essentially I'm going from a high point of 7.5' and following the template for about 16'.
I'd have a clean break there with a bumper recessed in out of flow, and the ability to hang a 3' boat tail for longer trips if it would do any good.
I have weights in mind. The combined weight should be between 11,500 and 12,000 pounds.
I have played with the calculator quite a bit. I figure I can get an average of .008 on the crr, using the best tires for each unit. I just discovered I can use the Bridgestone 381 with the really low crr on the trailer.
Just guessing from my results so far, I figure the Cummins 6BT at .29 thermal. The truck sucks hard at 34.5 ft and .44 cd. I think smoothing things up off the truck and finishing them off onto template with faired wheels should net the mid.2s for the combined rig.
2003 TDI Beetle
2002 TDI Beetle
Custom cab, auto, 3.55 gears
