An alternator with a clutch on it will still need energy to keep the clutch engaged. This will most likely be anywhere from 24-36 watts worth. You would need to save more than this for this mod to be effective. Plus you would have a clutch assembly that could possibly go out on you too. Some one else mentioned it is harder(takes more energy) to start it spinning from a stand still than it would be to keep it rotating.
 2002 VW Jetta TDI 5-speed(completed 01M-5-speed swap at 155K miles) 45 MPG City with the 01M, 5-speed 60+ MPG City. Nokian Entyre Low RR Tires. Experimenting with the "Hybrid" 205 Deg F T-stat:
http://forums.tdiclub.com/showthread...=306799&page=4
