as i sad, the simpel way is to keep trottle, injection and header etc. of the existing car and only go for the engine itself. what comes in and what comes out is pretty much the same in nowerdays. so if you can bolt this parts on, the engine will work.
2 points are to think of. how to drive the ignition (prius has coil on plug), and is the prius doing something with the camshaft.
