Old 01-18-2012, 04:04 PM   #5 (permalink)
Ken Fry
A Legend in his Own Mind
Ken Fry's Avatar
Originally Posted by TedV View Post
I'm more interested in the g/HP or g/kW chart to compare the thumper motor against other small gas or diesel motor.
For full throttle, the BSFC curve looks like the torque curve flipped upside down.
You could back into a number by comparing fuel efficiency at 120 k/h vs 90k/h, using the BMW specs. Rolling resistance remains essentially identical at those two speeds. Aero drag goes up with the square of speed, etc. (This is the same idea as a coast down test.) If you get where I am going, you can see how this can be done.
But I am not sure that you would get closer than just assuming 30% efficiency at peak for both the CBR and the BMW, and then looking at the shape of the torque curves to assess BSFC at lower loads. Comparing the published FE figures for each would let you fine tune this a little, and I would not be surprised if you found the BMW to be a little more efficient at peak (32% vs 30% maybe). But then accounting for the greater distance from peak with the BMW for a given (reduced) power requirement, should make the CBR a better bet. (I think you would need European test numbers for each -- I'm sure the US numbers are not obtained in the same way. )
This would be ever so much easier with a real BSFC map -- but they are very hard to find for motorcycle engines. The map could reveal a part throttle anomaly for either engine, that you could only guess at... at best.
In a previous life, I built and ran a motorcycle dyno at a motorcycle school. If you could find such a school, maybe they could put the bikes side-by-side. I used to use a pipette for fuel flow. You'd calculate the power you think you will need based upon your aero design, and run the dyno test at that hp. A DynoJet would be useless -- has to be a constant load type.
So... I'm not being much help here... wish I had the maps in front of me.
