Old 01-18-2012, 05:10 PM   #41 (permalink)
slowmover
90 day: 19.36 mpg (US)
I just discovered I can use the Bridgestone 381 with the really low crr on the trailer.
The only BRIDGESTONE 381 I'm seeing is LRR, but of passenger car spec and a load rating of under 1,200-lbs each. The suggested weight is indicating a tire capable of in of 3,000-lbs tire (tridem) or 4,000-lbs tire (tandem) with a real world tire (and wheel) capable of greater reserve capacity than this.
Did you happen to mean the same makers 16" 3,042-lb LR-E Duravis R250?
