Old 01-18-2012, 07:45 PM   #26 (permalink)
steffen707
Awesome work and results. Only problem I see is that you had 13 inch tires and 14 inch tires, leading me to believe you had to use different wheels.
My Civic VX wheels are super light 13", steel wheels are very heavy. For an apples to apples comparison did you use the same 13" wheels for each 13" tire, and the same 14" wheels for the each 14" tire?
Also what were the weights of said wheels?
Don't get me wrong, the work sounds awesome, and i'm super happy I bought insight tires for my VX swapped EK hatch ( I ended up using semi hollow miata wheels that are like 11-12lbs and 14", I couldn't find a set of insight wheels to use). Just curious on the wheels used.
