Old 01-19-2012, 12:58 AM   #8 (permalink)
alvaro84
alvaro84's Avatar
Teresa - '04 BMW F650CS
Motorcycle
90 day: 80.53 mpg (US)
The YARDIS - '99 Toyota Yaris 1.0
90 day: 59.52 mpg (US)
Originally Posted by Ken Fry View Post
...I would not be surprised if you found the BMW to be a little more efficient at peak (32% vs 30% maybe). But then accounting for the greater distance from peak with the BMW for a given (reduced) power requirement, should make the CBR a better bet.
This is why Pulse&Glide works quite well on my BMW F650CS, even without instant feedback (the earliest feedback I can get is at the pump).
OTOH if you look at my log (Teresa is my bimmer) and sendler's (Honda CBR250R FI Single is his CBR, not a big surprise ) you can see some difference in their FE, he can do 80mpg with the CBR around freeze point, while I'm in the low 70s even at the low speeds I can hold in cold. I often ride at 50-60km/h (~31-37mph), in 4th (because I have to) at those temps, so the engine efficiency must be pretty bad, but at least the aero drag is lower...
