Old 01-19-2012, 02:35 AM   #38 (permalink)
oil pan 4
If you are worried about low voltage not engauging lean burn why not make a higher voltage battery?
You could find a 6 and 8 volt battery from the same manufacturer that use the same cells just more or less of them in each battery and make your self a 14 volt battery.
