Originally Posted by aerohead
Yes,so far that's all we use it for.She's based on a complete body of revolution,but if done would be prohibitively wide,so that's a non-starter!
I'd started a plan-view drawing,then got distracted digging for other plan views to homogenize into some sort of generic form.
One size fits all sounds to me like a tall order.
Morphing the sides into the roof is tricky 'cause the velocities and dynamic pressures are different. Not a problem in the original body of revolution.
That's where I'm hoping good-enough CFD can help. Even without turbulent boundary perfection my hope is that pressure and flow balance as a function of roof/side taper aggression can be compared. In the case of an aerocap for a pickup, for example, the cab and box fixed geometries no doubt limit how much streamlining can be done.
So far,my gut feeling is that,after locating the position of max camber on the body side,mimic the roof curvature starting from the side zero point .
Progressing to the rear,begin to roll the sides into progressively steeper tumblehome ( as we see in the HONDA Fit B,C,and D-pillars),blending into the roof-line with slowly increasing radii.(extremely difficult to fabricate!).
That was a design goal for me when I drafted a concept cap.
I've been completely absorbed reducing the Trailer trip data since early October and have basically let everything else slide.
Focusing on your own priorities is completely understandable, Phil. It's too bad the weather was sh*t when I visited last month. For future reference next time I'd be happy to lend a hand wherever I can. Tuck the offer in your back pocket for consideration.
