Old 01-19-2012, 07:21 PM   #55 (permalink)
thingstodo
Ford Prefect - '18 Ford F150 XLT XTR
Tess - '22 Tesla Y LR
A little side investigation
Originally Posted by hamsterpower View Post
I have not read there in a while either, but if I remember correctly it started in this- Changing an induction motor voltage - The Australian Electric Vehicle Asn - Page 1
If anyone is interested, the linked thread is definitely worth a read. They get into a whole lot of theory .. and it looks like it should work ... there seems to be a requirement for the coils in the motor stator to be in series, and joined by an easily-identified 'link'
So I think I'll take apart the 3 motors that I have that are 5 HP as well as the one that is 40 HP and see if the coils ARE in series, and ARE easy to identify.
The thread has not been updated in a while, but I'll cross-post results if:
- my motors are suitable
- I can get the coils separated
- the extra wires fit through the grommet into the motor junction box
The VFD that I'm using for testing will put out 33A, which is 4 times the rated current of the 5 HP motors. That should be enough for me to verify their data ... splitting the phases into separate coils allows for good starting torque and MUCH higher speeds (and much higher power at the higher speeds), but the VFD needs to be oversized.
Some of the experiments they have documented in that thread were a bit scary - running rotors WAY WAY over 'rated' speed ...
If the motors can be modified, I can still run them 'normally' by wiring the 'separated coils' back in series as they originally were, within the motor junction box, so the mod can be 'left in' even if my tests don't work out.
This will be interesting ....
