Someone in an other thread posted about using a 8 and 6 volt batteries to get the optimal 14 volts. The trick will be charging with a panel and it would be a bit pricey, but I need at least one battery anyways... Would a 12 volt panel work? As I said in the other reply... 12v panel open is 18 to 21 volts. Wonder if it would charge a 14v. Course panels are not hard to make and a custom panel would be no harder to build than any other voltage.
3585 pounds of twisted steel.
Recreational | Active | Vehicle | 4x4
...scratch that... AWD
