Old 01-19-2012, 09:12 PM   #5 (permalink)
oil pan 4
Can NiMH even supply the demanded cranking amps?
Not reall, but it is possible. The problem with NiMH is you can only hope to roughly get about the amp hour rating as your amp out put, your standard AA size 2300mAh battery will only put out about 2 amps, a true D size will only put out maybe 8-10 amps per row of cells.
Each stack of A123 LiFePO4 cells is good for 110 cranking amps and a whole lot of load amps.
