Old 01-19-2012, 11:00 PM   #44 (permalink)
rmay635703
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
Originally Posted by lacolocho View Post
Hey all, new to the forum.
I'm considering swapping diesel engines into 50s or 60s American cars and was referred to a post on this forum by someone over at the Benzworld.org
What do people think of doing such a swap?
I think the swap is just fine, most people driving a classic around here took out the straight 6 or 4 banger and put in a 350 and made a tricycle out of it.
I myself had my 82 6.2 diesel swapped into another suburban with a 5sp MT. for a craftmobile. The key with 6.2s is to stick with the C code motors (pollution control) and keep them slow and lumbaring preferably with a manual transmission and a nice high rear end. (2.5's/2.8's with an old 3sp + granny is best) I considered strongly swapping my 6.2 into a big cheap motorless ancient bently with a nice Scrooge McDuck look. I might be alone in that line of thought however. I was thinking I could keep the motor to the rear of the engine bay and use the rest as a trunk.
Anyway An 82 C-code 6.2 with good heads and bolts will last 500k as long as the harmonic balancer is decent.
A 6.2 is good at fuel economy but not at power, that is all you need to know, abuse it and loose it.
Oddly the same is true of the 5.7 olds and good wrench, I see many of them lasting in the 500k area so long as people added
1. Fuel water separators
2. Replace the head bolts occasionally.
Those that didn't have vastly different oppinions of that same motor.
Also my 82 6.2 still has the original pump, sadly I have an air leak which makes it hard to start but once running it is just fine and pokey as it was designed to be. The air leak has messed up my accellerator pedal (nothing then vroom) but I think a lift pump might fix it.
A 6.2 is a MUCH better idea than a Ford product because it is just about as easy to install as a 454/350 and can use all of the same parts and it is MUCH lighter.
Cheers
Ryan
