Originally Posted by thingstodo
...15 minutes later (after putting things away in the garage) the battery string is at 101.1V standing voltage. This is higher than I was expecting. It is 1.42V per cell. I guess I should check later.
Well, I forgot to check the voltage that day. I checked today and the battery string is sitting at 98.1 VDC, and the battery string is outside at -19C or just below 0 fahrenheit ... maybe 1 below. I expect that the voltage would drop quite quickly if I put a load on it.
