Old 01-20-2012, 05:19 PM   #10 (permalink)
Daox
Increase air temps have been known to increase flame speed which increases efficiency. Also, hot air is less dense requiring a larger throttle opening to maintain the same power. So there are benefits to be had from warming the intake air.
Even if the core is a restriction, you're simply moving the restriction from the throttle to the core. If that is the case he'll notice a drastic drop in power, so it should be pretty apparent.
