Ug 1.2
The power down feature has 2 discoverable options. Option 2 is the default and recommended. You can select 1 or 2. 2 uses less power when the ignition of turned off if your vehicle supports the protocal. You can repeat gauges on multiple screens. There are 7 screens total but you have to unlock them if you want more that 3.
