Old 01-22-2012, 11:34 AM   #27 (permalink)
Formula413
Renaissance Man
Formula413's Avatar
Aegean C - '17 Honda Civic LX
90 day: 39.02 mpg (US)
Originally Posted by RH77 View Post
My main concern has been with the (still original) automatic transmission experiencing higher temps. As a result, I did invest in a fully synthetic fluid flush/replace. Even with it hacked to shift the torque converter manually, it still has a firm shift with no excessive slippage or shudder (knock on wood).
Not to threadjack but if you are running a warmer thermostat you would probably be well advised to add a transmission cooler (maybe you already did?). Since the trans fluid shares the radiator with the now warmer coolant it is most likely actually being warmed by passing through there. I would bypass the cooler in the radiator and run an external cooler, and put it somewhere where it will get good airflow.
