Old 01-22-2012, 04:43 PM   #28 (permalink)
Josh8loop
Definately a Modder!
Originally Posted by Formula413 View Post
Not to threadjack but if you are running a warmer thermostat you would probably be well advised to add a transmission cooler (maybe you already did?). Since the trans fluid shares the radiator with the now warmer coolant it is most likely actually being warmed by passing through there. I would bypass the cooler in the radiator and run an external cooler, and put it somewhere where it will get good airflow.
Little of topic as mentioned, but I was thinking the same thing in regards to tranny temps. When I first experimented with higher temps and had my automatic I wasn't too concerned since I was planning on a manual swap soon anyway. I am sure he is well aware of the potential issue, and is looking for ways to combat ill effects.
2002 VW Jetta TDI 5-speed(completed 01M-5-speed swap at 155K miles) 45 MPG City with the 01M, 5-speed 60+ MPG City. Nokian Entyre Low RR Tires. Experimenting with the "Hybrid" 205 Deg F T-stat:
http://forums.tdiclub.com/showthread...=306799&page=4
