You should also notice that if you have ksenon headlamps they don`t worn out so much and you don`t have to change the expensive light bulbs so often. Which can be even bigger saving than the electrical load savings
. Same goes for regular halogens also if your car is so difficult to replace the bulbs that it need to take out the front bumber etc at car service which takes time and costs money.
