Old 01-23-2012, 12:10 PM   #49 (permalink)
Diesel_Dave
Diesel_Dave's Avatar
White Whale - '07 Dodge Ram 2500 ST Quad Cab 2wd, short bed
90 day: 37.68 mpg (US)
Originally Posted by drmiller100 View Post
interesting.
i did not know you could have higher intake pressures then exhaust pressures. thinking about it, theory says it sure is possible. though.
thank you.
You're welcome. One thing that's worth mentioning is that most EGR engines cannot have higher intake pressures--otherwise the exhaust wouldn't flow into the intake. That's one of the reasons some recent diesels (including my truck) are fitted with intake throttles. In situations where the intake pressure is too high to get enough EGR flow, the intake throttle is closed down to increase pumping losses. One more way EGR hurts fuel economy on a diesel.
On a gas engine EGR can actually help the pumping losses because more EGR allows the throttle to be more open (because fuelling is deterined by the oxygen content in a gasser), therefore EGR raises the intake manifold pressure.
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
