Old 01-23-2012, 10:01 PM   #22 (permalink)
drmiller100
namely almost no cooling is required, and this would improve the Cd by about 10% right off the bat. Also, the lack of a hot exhaust system means the belly pan can be completely smooth (without also causing a heat problem) so that's probably another 10-15%.
cough cough..... gag..... Ummm, No.
I encourage you to build your car however. Prove me wrong!!!!!
