And my favorite bit of misinfo:
...somewhere around 10 to 12 years and 100,000 to 150,000 miles, most cars start failing in increasingly expensive ways.
If they're built by Honda or Toyota, you can probably double those numbers. I have a 2000 Honda Insight and a 1988 Toyota pickup, and yes, I will admit both have mechanical "failures" at the moment. The Honda has a burned-out headlight bulb (and the driver's floor mat is worn); the Toyota needs a new speedometer gear. But I can't see these failures adding significantly to either their operating cost or carbon footprint.
