Old 01-24-2012, 12:35 AM   #42 (permalink)
Grant-53
I just sent some e-mails to Craig on aero mods for the front of Alan's Ninja. Remember that the center of pressure on the front wheel fairing needs to be behind the steering axis. A profile for the bike needs to be an inverted wing shape to generate some down force. For those going for the trash can tail box, check the Rubbermaid #2979 Roughneck 30 gal. Experiment with cutting slits in the 4mm Coroplast and overlapping sections to get the curves you want, use cardboard from cereal boxes to make 1/4 scale models until you get the shape you like.
The Following User Says Thank You to Grant-53 For This Useful Post:
HHOTDI (01-25-2012)
