Originally Posted by CigaR007
Oddly enough, diesel used to be cheaper than gasoline, at least where I live.
Same here, my truck misses the $0.99 diesel it was used to.
Originally Posted by sendler
That's a crazy,radical piston. domed with a cavity. Lots of extra surface area. But Mazda says it wastes less heat by keeping the flame contained in the cavity.
The VW TDI uses a similar reverse dome with a peak piston. It creates less "wall stick" and more evenly distributes the fuel.
The good thing about a lower CR is you can add more boost without excessive peak cylinder pressures.
Wonder what size nozzles they are using and when bigger ones will be available
