Old 01-25-2012, 04:05 AM   #77 (permalink)
oil pan 4
Originally Posted by IamIan View Post
then I to would never have to leave lean burn .... hmmmm....
The problem with staying in lean burn under heavier load is it can cause pre-ignition and possibly burn exhaust valves.
Spending much time under load in 13.2 and/or 15.7 to 1 air fuel ratios burns exhaust valves.
13.2:1 creates the most torque and highest EGTs, but EGTs and NOx peak at 15.7:1.
Anything much leaner than 16:1-17:1 (around where honda lean burn is) burns at a good temperature but doesn't create much power, getting up to speed on the highway, passing and going up mountians could become a problem.
