Old 01-25-2012, 12:18 PM   #95 (permalink)
Diesel_Dave
Diesel_Dave's Avatar
White Whale - '07 Dodge Ram 2500 ST Quad Cab 2wd, short bed
90 day: 37.68 mpg (US)
IMO smaller engines are thought of as more efficient because in order to get the same power out of the smaller engine, you have to run at a higher %load. That's where the higher engine efficiency is coming from--not from the smaller engine itself. If the larger engine were at the same %load, it would be more efficient.
Another thing to remember about running lower rpms is that both friction and pumping losses decrease with speed.
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
