Old 01-25-2012, 02:52 PM   #102 (permalink)
some_other_dave
Mount them on the other side of the disk. Or possibly next to the regular caliper (above/below). Regardless of which way you go, you'll have to fab up some brackets for them.
Another thing that has been considered by kit-car people is, if your car has a CV joint right at the differential's output flange, to sandwich a thin rotor between the flange and the joint. Then mount the caliper to the diff.
-soD
