Old 01-25-2012, 05:46 PM   #23 (permalink)
DieselDrewski
Shop Rat
DieselDrewski's Avatar
Last night, I finished putting together the dash (still a lumber of loose ends there, literally and figuratively), filled the crankcase with oil, and the radiator with antifreeze. I put a temporary fuel container under the hood, did my best to purge the lines, and tried firing it up. I couldn't get it to catch (definitely air in the fuel system still) so I'm going to complete the fuel system build before I try again. I plan on using the fuel pump in the tank as-is, but I found some low pressure switches on the Mendelson's website, so I bought a couple, along with some other odds and ends. I hope the connections for the switches are a standard type; there isn't much info on the page. From experience, I know that trying to wire the pump from one switch is likely to cause a lot of cycling within a narrow range, so I designed this circuit:
The pump will run until the high pressure is reached, but not turn on again until it drops below the low pressure.
1990 Geo Tracker with Kubota D950 diesel (work in progress)
1993 Ford Festiva with Yanmar 2TNV70 diesel
2004 Jeep Wrangler Rubicon with Scangage
2008 Nissan Rogue S
"This is only temporary, unless it works"-Red Green
