It depends if you have high or low impedence injectors. I remember some of the M20s had LOW while all EV6 injectors are HIGH. Check to make sure first. Also the 2.5 liter M20 had 17# injectors so I assume your 2.0 is 17# or less. EV6 injectors in that range are hard to find. They usually start around 19#. I swapped over my old 1991 M42 years ago, still runs great with its current owner.
http://farm3.static.flickr.com/2319/...79b3f801_o.jpg
http://i402.photobucket.com/albums/p...s/DSC01724.jpg
