Old 01-26-2012, 01:37 PM   #4 (permalink)
320touring
The Mistress - '88 Bmw 320i Touring SE
Team m8
Last 3: 27.17 mpg (US)
Germany Beadle - '91 Mercedes 300td (estate, N/A)
90 day: 24.63 mpg (US)
The Bloodylingo - '05 Citroen Berlingo Multispace Desire
90 day: 39.77 mpg (US)
Shanner Scaab - '03 Saab 9-5 estate Vector
90 day: 26.19 mpg (US)
Clio 182 - '05 Renault Clio RS 182 182
90 day: 31.73 mpg (US)
Originally Posted by tjts1 View Post
It depends if you have high or low impedence injectors. I remember some of the M20s had LOW while all EV6 injectors are HIGH. Check to make sure first. Also the 2.5 liter M20 had 17# injectors so I assume your 2.0 is 17# or less. EV6 injectors in that range are hard to find. They usually start around 19#. I swapped over my old 1991 M42 years ago, still runs great with its current owner.
http://farm3.static.flickr.com/2319/...79b3f801_o.jpg
http://i402.photobucket.com/albums/p...s/DSC01724.jpg
the m20b20 runs at 2.5bar as opposed to the 3bar of the 2.5..
I've got the specs for the injectors in the car- they flow 12.65#
here's the details:
Part Number lbs/hr cc /min grams /min PSI BARS lbs/hr cc /min 80% 95%
0-280-150-208 12.65 133 95.68 36.25 2.5 13.86 145.6 19.5 23.1
they also show as EV1 and High impedence
That looks like good work you did on the m42- was it in an e30 then?what injectors did you use?
I'm struggling to find injectors with similar flow rates- the 2.0 6cyl needs relatively little per cyl per cycle- all the 4cyl stuff flows much heavier
ALso, any ideas whether the 4 hole injectors would benefit from a raise in fuel pressure to the 3bar that the 2.5 has?
My Blog on cars- Fu'Gutty Cars
http://fuguttycars.wordpress.com/
US MPG for my Renault Clio 182
