Old 01-26-2012, 02:49 PM   #25 (permalink)
DieselDrewski
Shop Rat
DieselDrewski's Avatar
Originally Posted by Diesel_Dave View Post
Do lift pumps typically cycle on an off? I thought they just stayed on all the time.
What type of high pressure (injection) pump is on the Kubota?
Just to be sure we're on the same page, the electric pump is the one in the fuel tank that provided pressure for the original gasoline EFI. The Kubota has a mechanical feed pump going into a Bosch K-type mini injector pump.
I think the electric pump would have normally run all the time, but also would have a pressure regulator with return line to minimize pump load.
I may discover that no pump is required.
1990 Geo Tracker with Kubota D950 diesel (work in progress)
1993 Ford Festiva with Yanmar 2TNV70 diesel
2004 Jeep Wrangler Rubicon with Scangage
2008 Nissan Rogue S
"This is only temporary, unless it works"-Red Green
