Old 01-26-2012, 07:43 PM   #106 (permalink)
some_other_dave
Jack, do some testing to make certain about where brake lock-up occurs. There are adjustable proportioning valves that you can buy that will limit pressure to the rear brakes, so if the car is too rear-biased you can fiddle with that to some extent.
The time when you are most prone to rear brake lock-up is on a downhill with excellent traction--having good grip under braking will transfer more weight forward than having low grip.
-soD
