Originally Posted by Ecky
Is everything 100% hooked up? I don't suppose VTEC is engaging like it should, is it?
There pretty much is no Vtec at the moment. I hooked the 12 to 16 valve switchover to a switch, but without the ecu, the lean burn doesn't activate at all yet. I usually keep it at the 12 valve setting and have had no problems with acceleration or power even at highway speeds. If anything, the car is actually more fun than it was with the SI in it.
