Old 01-26-2012, 09:40 PM   #10 (permalink)
bikin' Ed
my solution
On my Dakota, the hood latch has to be pulled down. I attached a piece of plastic tubing to the inside of the grille with nylon wire ties. Then attached a piece of semi rigid wire to the latch. I fed the wire thru the tube to the bottom of the grill. Make a small loop in the end of the wire and hang it between the bumper and grille. A pull on the loop does the trick.
