Old 01-27-2012, 09:33 AM   #9 (permalink)
johnunit
Originally Posted by Sven7 View Post
First of all I'd be careful using plexi underneath the car in case it cracks. Maybe use some moderately deformable plastic like acrylic. And you can't lose with coroplast. I drove for months with the coroplast belly pan and haven't seen any damage. And it's cheap!
Interesting, I hadn't thought about the shattering risk. Very good point.
For the wheel thing, I was saying that lowering the car would more than make up for the increased area of the wider tires because lowering it decreases frontal area. The car's body curves in so much that I don't think any wheel fitment is really going to benefit you (unless you ran 20* positive camber with 18" flat face wheels). You'll always have the tires poking out the bottom and tucking in up top. For a car with flat sides like a kei car it might be worth the money/effort. For a pre-90's American car I really wouldn't even bother. Put your effort toward belly pans.
Looking at my car again, I see your point. "filling in" the top of the fender well is always going to result in sticking out more at the bottom. That's probably the answer to the original topic of the thread right there.
The spoiler was an idea. I don't know whether you could pull it off or even find one for that matter. It probably will look weird, that coming from a guy who likes the look of Wartburgs.
There are no contoured/fitted wings or spoilers of any sort available for "Box" era Panther chassis cars that I'm aware of. I'm not sure whether you could come up with one that could look decent and have any positive effect either. It's something to play with if and when the car gets a full repaint, I suppose. At that point I'd mock up a few different looks out of sheet metal. Getting the lines right with the looong overhang and the angle the trunk slopes down at would probably be a pravneet though.
The "plausible stock" thing is what VW guys call "OEM+"- it looks stock, but with a few tasteful improvements. I'm not sure if other people use that term but it might help explain it at least with VW people
Interesting. I might start using that term.
2001 Prius - 170,000 KM - just got it (no consistent FE numbers yet)
