Old 01-27-2012, 11:31 AM   #29 (permalink)
DieselDrewski
Shop Rat
DieselDrewski's Avatar
I worked on purging all the gasoline from the tank last night, using first the in-tank electric pump, then resorting to a manual piston transfer pump to get the dregs out. Then I flushed 3 times with diesel. Today, I'll put in diesel for fuel and plump the engine. From the way I was able to draw through the un-energized electric pump, I think the mechanical feed pump on the engine should be sufficient. I might wire in a momentary switch to the pump to make bleeding the system easy.
1990 Geo Tracker with Kubota D950 diesel (work in progress)
1993 Ford Festiva with Yanmar 2TNV70 diesel
2004 Jeep Wrangler Rubicon with Scangage
2008 Nissan Rogue S
"This is only temporary, unless it works"-Red Green
