The throttle body is actually 1.77 square inches. 38mm diameter. His calculators don't allow to fix the area and calculate just the length vs rpm. I assume that the stock 1.77 square inches will still fairly closely follow theory for a 14 inch runner resonating at the desired 6,000 rpm. The over sized cross area only serving to broaden and round off the peak slightly.
