ok I find out in one junkyard there is lupo 3l already with conversation to full mechanic gear box. he asking 300euro for kit so in total its good deal. but he said that its not same ecu, so probably 1.4tdi. now I read little bit detail brochure about 3l and there writing and how I understand you can achieve that ultra low fuel consumption only with ECO button, what reduces the power. If ECO mode is off, so it's normal or how they said sport and in that case you can output those 61hp from engine, right? so if you keep it original 3L ECU you set ECU keep all time Drive mode (where normally on DSG you can shift up/down manually) and you can't achieve 3l fuel consumption?
Vekke, ok little bit later.
