Old 01-29-2012, 04:49 PM   #185 (permalink)
Vekke
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
You can get that 3 liter fuel consumtion even with 61 hp. What the eco button does it reduces the power and torgue output and this means gas pedal is not so rapid and the acceleration is easier to control. There should be only one map inside the ECU
ECO button also enables the neutral gliding which lowers a lot the fuel consumtion. You can do that with manual also.
With my current knowledge more power you have on smaller engine the better fuel consumtion figures you can reach if you use it correctly. This means you need to know how to make gear changes in same points as the car would have done in ECO mode. Also in some circumstances you can change much better because you can estimate the road ahead better that the ECU.
What you should notice that Lupo and polos have basicly the same 085 gearbox, but Lupo 3L has the best gear ratios for low fuel consumtion targets. So if you just switch a regular manual gearbox to lupo 3l you fuel consumtion will get higher for sure.
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
