Old 01-31-2012, 08:41 AM   #60 (permalink)
sendler
sendler's Avatar
90 day: 105.14 mpg (US)
90 day: 60.68 mpg (US)
90 day: 38.51 mpg (US)
PCX153 - '13 Honda PCX150
90 day: 104.48 mpg (US)
90 day: 80.94 mpg (US)
90 day: 72.57 mpg (US)
Here is what I learned so far about importing a Canadian vehicle to the USA.
Please follow the instructions below for importing a Canadian vehicle.
1. Contact the Manufacturer for a letter of compliance that states the vehicle complies with all U.S. Federal EPA and DOT requirements. A list of U.S. Representatives can be found at Importing Vehicles and Engines into the U.S. | Transportation & Air Quality | US EPA
2. Obtain the EPA form 3520-1 from Importing Vehicles and Engines into the U.S. | Transportation & Air Quality | US EPA
3. Contact the DOT at 202-366-5291 or Vehicle Importation and Certification Requirements for the HS-7 form and DOT import regulations.
4. Once you have the letter from the manufacturer, the EPA form and the DOT form, you will need to present all three documents to customs for a customs release form which will allow you to title and register your vehicle in the U.S.
· If the manufacturer states that the vehicle is not compliant with the U.S. Federal emission standards and there is not a retrofit available, you will need to contact an Independent Commercial Importer (ICI) to have the vehicle modified, tested, and certified.
If the manufacturer does not issue a compliance letter, you may not be able to import the vehicle. A copy of the compliance letter from the manufacturer is also required by Customs and DOT.
David C. Hurlin
URS, Contractor
EPA Imports Line
Imports Group
Compliance Division
Phone: (734) 214-4100
Fax: (734) 214-4676
2000 Traverwood Drive
Ann Arbor, MI 48105
The Following User Says Thank You to sendler For This Useful Post:
HHOTDI (01-31-2012)
