Where are you getting this free fuel from? I use grocery points at Kroger, usually getting about $0.50 off per gallon for one fill up per month (which is usually all I need). Is this the type of thing that you're doing?
Yeah a belly pan should help. I've planning one, but haven't gotten around to it yet.
Depending of how much you haul stuff in the bed (or if your trailler is a 5th wheel), you might want to look into a bed cover.
Just a note as well, some people with towing trucks keep 2 fuel logs--one towing, one not. You may find that works well for you.
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
