Old 01-31-2012, 09:27 AM   #32 (permalink)
Diesel_Dave
Diesel_Dave's Avatar
White Whale - '07 Dodge Ram 2500 ST Quad Cab 2wd, short bed
90 day: 37.68 mpg (US)
I'm going to have to get one of the right angle ones, becaude for me it's not just the cable that's in the way but the actual "box" (before it forms a cable).
Anyway, I played around with it some more. It's reading the engine okay, i.e, I can get coolant temperature, engine speed, etc. but I can't get the fuel economy to work.
I assumed for diesel, I should select the direct fuel calculation method, but that gives all zeros. I tried the MAF method just to see what happened, but it gives bogus numbers (average of 70+ mpg), and reads zero fuel flow at idle.
I sent a note to the OBDwiz support, asking what I'm doing wrong. When I get a chance I may dig through my logger to, to see if I can make out anything.
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
